An attempt to configure a Route Target with a value that is identical to another Route Target in the same VRF was made. The Route Target configuration is rejected. Only one Route Target of a given type may be configured in the same VRF.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Error
An attempt to configure a Route Target with a value that is identical to another Route Target in the same VRF was made. VRID = %p1% VRF name = %p2% Route Target index = %p3% Clashing Route Target index = %p4%
| Name | Type |
| p1 | xInt32 |
| p2 | CharByteArray |
| p3 | xInt32 |
| p4 | xInt32 |
